2 hours ago
an hour ago
HI @NourChe
LTE is 4G. So, you can use that option
and what network you are connected to now? did you try to manually connect to all networks? T-Mobile and AT&T and Verizon?
2 hours ago
I don't have the 4G option
My phone is showing LTE/3G/2G option only
Thanks!
2 hours ago
2 hours ago
No options for 4G
2 hours ago
Critical part to US roaming depends on T-Mobile/AT&T/Verizon coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T/Verizon, change the Network Connection from Automatic to Manual and select and test each of the three and see which one you can connect and work best
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter. Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
2 hours ago
@NourChe Make sure you have data roaming turned on in phone settings , and set phone to 4G/LTE not 5G and make sure your connected to T mobile /AT&T or Verizon and test again
