2 hours ago
hello,
a couple of days ago I had changed my wife's plan to the 35 dollar plan which started on the 3rd of Oct. Today, October 4th she cannot make outgoing calls. She can text, receive calls but when she receives calls she gets no caller id.
when she tries to call out she gets a message saying she is not active on the network.
Is there a solution for this? thanks for the help. @CS_Agent
2 hours ago
hi @deannap
please login My Account again using Incognito/private/secret mode on the browser and check if the payment was done correctly and on time. Check if the account is active, check if the Subscription period is correct and check payment history
if anything not right, you will need PM support agent to help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 hours ago - last edited 2 hours ago
@deannap first suggestion would be to turn off phone and then restart. Nothing really should have changed on your settings so if you're still having issues try opening a ticket and get a CS agent to investigate on their end:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
