11-21-2024 02:07 PM - last edited on 11-22-2024 02:02 AM by computergeek541
phone generates the message “cellular network not available for voice calls”
11-21-2024 02:09 PM
hi @Renae3
first, remove the phone number as this is just a forum with customers. Go back to the post, top right corner down error and Modify Message and remove
For your voice problem, we saw many this week
Try reboot your phone, try Reset Networks settings
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
