Need to reactivate account to switch service providers
LordPotato
I need to reactivate my account in order to switch service providers. Is there any way to temporarily reactivate without needing to pay for another month? Thanks!
pkaraa
So the account is inactive now..
Depends on which provider you are porting to... as mentioned if porting to Telus family, you dont need to reactivate as it is family business. If leaving this family then there is a cost attached ...atleast $15. If it is that kind of a sweet deal that you ll spend $15 and still benefit from it then go ahead otherwise choose a suitable plan and stay with all the rewards. (between you n me..... someone said there might be a dec bonus for existing clients coming real soon.... not sure but most likely.)
@LordPotato   are you changing to Telus or Koodo?  there is a chance if that is the case but this is still upon the cs agent decision
if you are moving elsewhere, then you really should reactivate your account first.  Make sure your account was suspended less than 90 days.
To lower the cost, you can change your plan to $15 first and then reactivate with this lower cost plan.
ShawnC13
How long has the plan been inactive?  If over 90 days your account has been closed and the number has been returned.  If it is under that as others have said unless you are going to Telus or Koodo you will need to pay for a new 30 day cycle and the lowest plan for that is $15
@LordPotato
No. you have to pay is nothing for Free...
Reactivate a suspended plan (publicmobile.ca)
walker1
@LordPotato
Nope, not unless you're going to Koodo or Telus, then you don't have to pay to reactivate your account.
If not, you'll have to get the $15 plan at least. Sorry 😐
