08-29-2023
06:29 PM
08-29-2023
08:15 PM
computergeek541
I just realized I am having the number port error and have been missing work calls for like a week now lol How do I have a moderator force my number transfer through asap. Any help asap is appreciated! Thanks!!!
08-29-2023 06:38 PM
@Doomsick Please submit ticket with support . or you can try the porting team number also to see if they can re trigger the port request for you will send you that number private message
send a private message To CS_Agents click
VVVVV Link below VVVVV
08-29-2023 06:32 PM
When you initially Ported in did you use the Previous Providers Account Number or the IMEI Number?
Did you approve and Reply 'Yes' to the Port Request from your old Providers SIM Card?
08-29-2023 06:32 PM
hi @Doomsick
you can call the porting team and they can re-initiate the porting for you. I will send the number to your Community inbox
