Poet Numbers Wrong one...
Iam2fast4you
I have an account and number with Public.
I attempted to port another number I own from Koodo but instead they ported the number from my Koodo to Public using the phone I already had on Public
So now my phone has my kids number, he has no service, and my original phone number is gone.
Suggestions???
Phil_Adelphus
@Iam2fast4you  That's because you can only have one number per account, so the system assumed you were porting in a number to the logged in account to replace the existing number.  You will need to set up a separate account with a different email address for the other number once customer support has hopefully fixed the problem.
eddieO
@Iam2fast4you not sure if this can be undone but you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
@Iam2fast4you
luckily they are all within Telus family and likely the wrong can be made right again.
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
