Login issues
07-06-2024 04:51 AM
I got a sim card online and it's been active for over 2 months. Each time I try to log into my account, I get the message "Let's complete your activation"
My Account
07-06-2024 08:30 AM
@Mails4ekhator, it looks like you are using the PM app. Are you using Android or iPhone? If Android, try going into your phone's settings and clearing the data/cache and then logging back into the PM app to see if you can complete the activation. If you are using iPhone you will need to uninstall the PM app, restart your phone and then reinstall the PM app and log back in and try and complete the activation. You can try activating through a web browser as well but activating the SIM card needs to be done through the PM app.
If you continue to have issues you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
