Porting out
Deb9812
I want to port out my number to Bell
2 REPLIES 2
Dunkman
eddieO
@Deb9812, should be no problem as long as your Public Mobile account is still active, Bell will initiate the porting so you don't have to do anything on your end. Keep your PM SIM card in your phone until you receive a text message confirming you want to port out your number, you will have 90 minutes to respond Yes. After this point you can remove your PM SIM and install the Bell SIM card and wait for the porting process to be completed, that's pretty much it.
