a month ago
When I login, it sends a one time password to the wrong phone number. I can only login by pressing "did not get code" and selecting to receive the OTP via email.
a month ago
Hello @ PubMob8372,
You will need to access the community account in My Settings-Personal-Account Information and verify if the phone number is correct. Then, on the same page, go to Manage Ever Safe ID, check here as well if the phone number is correct, if not, update it. Then log off, log in again, and check once more if you receive the code.
a month ago
The phone number in Profile is correct (ending in 450), but the number for my OTP is still wrong (ending in 021).
a month ago - last edited a month ago
So good, you are able to login. When logged in, click on or change the drop-down from the Overview, to Profile. Then Manage Eversafe ID. The phone number is showing. Is that not your phone number? Click the pencil to change and save.
