Canada US Plan
08-29-2023 06:00 PM
I recently signed up for the Canada US plan. I am in the US now. Text and data work fine but I cannot make phone calls. Two weeks ago my wife was in the US and had the US add on. She could not make phone calls either. Is there a fix?
Service
08-29-2023 06:36 PM
It's likely a VoLTE (or lack thereof) issue. What phone are you using?
08-29-2023 06:19 PM
Thanks @dust2dust for keeping me on my toes!
08-29-2023 06:12 PM
@maple_leaf- That roaming option is for data, not talk.
08-29-2023 06:10 PM - edited 08-29-2023 06:18 PM
Hello @Athena_high , Also, check your phone's network settings (if Android, Network and Internet > SIMs > Roaming) to make sure that it is toggled on. That's for voice calls. ( @dust2dust is correct, that's for data). Meant to say under Network and Internet > SIMs > Network , toggle on "Automatically Select Network". If "Automatically Select Network" was already selected, you can do as @Chalupa_Batman suggested, and toggle that off and manually select T-Mobile (and reboot). There's a separate setting in the Messages app, Messages Settings > Advanced > Auto-download MMS when roaming.
Also, U.S. Roaming Troubleshooting can be found here: https://www.publicmobile.ca/en/on/get-help/articles/us-roaming-troubleshooting
Hope this helps.
08-29-2023 06:09 PM
Do you know if your phone had been enabled for volte here yet? If not then your only option for talk is on T-Mobile and using their old 2G GSM network. Does the phone allow you to select 2G GSM? If not then that's another problem.
You might find some luck if you currently have 5G etc set and to set it to 4G LTE etc.
Text will also work on 2G GSM but not data.
Text and data will work on either T-Mobile and AT&T. The latter if set to 4G LTE.
08-29-2023 06:04 PM
Hi @Athena_high
Go into your network settings and turn off automatic. Then pick Tmobile and reboot. Let me know if that worked
