3 hours ago
Hi, I would like to change my phone number, however it doesn't give me a list of numbers, it just shows tat I can put any number i like. Could somebody explain how this thing works to change to a new phone number, because I don't want to lose my current number. Thanks in advance.
3 hours ago
Public mobile has its own pool of cell phone areas for different locations across Canada.
Here is some more information:
https://www.publicmobile.ca/en/ab/get-help/articles/change-phone-number
You can look around the various available numbers for your area. Don't confirm your choice unless you really want that number.
3 hours ago
Hey @discipline
Another option if you already have one in mind, if you have any VOIP apps and you've had them for at least 6 months, you can port those numbers over. If you don't like any of the numbers offered by Public Mobile, then go find a good number on TextNow or Fongo and hold it for 6 months and you can port it on over. You can change numbers up to 4 times a month. So you can it to something better for now to avoid others but get that special number you like from VOIP. It's a great idea, I did it.
3 hours ago
@discipline You can keep refreshing the page for more options like this in your account profile page, also not you can change phone number 4x for free every 30 days
Change # on profile tabs
