Referral Code
GVR
Is there any way to get my referral code before my account is fully activated? I'm waiting for my SIM to be delivered but my wife would like to sign up for an account. We'd like to make sure we don't miss out on the referral bonuses.
9 REPLIES 9
You can't just show up at the Telus store to pick up the free sim.  Make sure you arrange with PM before
Message them here
GVR
Unfortunately, not. That would have been the best solution 🙂
@GVR wrote:
Thanks again @Chalupa_Batman
There's a Telus store near by so I'll pop out and pick up a SIM then finish the new registrations.
Just wondering @GVR is eSIM not an option for you?
GVR
hi @GVR after your account is fully setup, you can login My Account to get try code from there
@GVR wrote:
Thanks @Chalupa_Batman
Are you saying that we can apply a referral code to an account after the initial sign up? If so, how would I go about doing that?
So the way it works is once you've fully signed up, SIM card is registered and you have a phone number, that means the account is complete. You can then go to your account and see your referral number. You can however pick a SIM card up faster. Here's how... give me a sec while I find the links.
EDIT:
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
Now, what you do is this. You will either pay the $5 or $10 at the store if one is close to you, then you contact a CS Agent via the chat box in the bottom right corner. Advise them you purchased a card because it was taking too long in the mail and they will gladly credit you the amount you paid (but not the tax) and credit your account if you ask them. Easy as pie.
hi @GVR sorry no
yo get it up faster without waiting it to be shipped, you can buy one yourself from Amazon for $5.  But that but the referral $10 in half 😞
GVR
Chalupa_Batman
Hello @GVR
Sadly no. Once your account is registered or your SIM card is fully activated, then you can then get your referral code. What you CAN do is just sign her up and then use HER referral code. Either way, win win right? Isn't marriage 50/50 or as mine tells me, 0/100 in her favor. LOL
