My plan has 250 mb of data, the network is stopping at 150 mb
cattersley
My plan has 250 mb, last month my service was cut at 150 mb. This month it was cut at 150 mb again. I can't access anything online through data just like last month. My phone has now said I've used 180 mb, but when logging into the public mobile website it says Ive reached my 250 mb. I need help...
Yummy
What your PM account says - how much data did you use?
Check data usage, download Excel sheet. Your phone's tracking might not be as accurate as PM's tracking.
@cattersley   you have a phone data counter to keep track of the data?
Just want to confirm did you reset the phone counter on the same data as your current  PM cycle start date.  Remember that PM cycle start dates keep changing, it is NOT ALWAYS on the same date of the month.  PM is running on 30 days cycle, not monthly, so, the cycle date will shift up one day after a 31 days month
Another way to confirm the date is to login My Account, go to Usage history and download the full usage on xls format (DO NOT just use filter on the page , there). Once the xls file is download, you can then use Excel to filter out the data usage and add up the usage from the first day of your current PM cycle
Shan15
Hi Cattersley,
I have a similar issue like you. I have sent a message to Public mobile agent and will update you once I get a reply from an agent.
Thanks!
