08-06-2022
03:24 PM
08-06-2022
08:09 PM
computergeek541
I cannot make or receive phone calls, and was getting a message that I haven’t paid my bill. Looking at my account online, my plan is active and I paid my bill (also autopay is active). Please help? Thank you.
08-07-2022 01:38 AM
ok.😞
08-07-2022 01:25 AM
@Timer The same thing was said 10 hours earlier. Please try to stop repeating others.
08-06-2022 07:24 PM
There could be a Telus outage in your area.
Check map of your area:
08-06-2022 06:07 PM
Can you be more specific about the message you are recieving? And where? When you try to make a call? When you call 611? What is your plan?
08-06-2022 03:30 PM
@bdostatnia where are you getting this message about not paying your bill?
Active, good.
Autopay, good.
But not in/out calling, not good.
Try 1 or more of the below for your calling issue:
- restarting your phone
- toggle into / out of airplane mode
- remove and reinsert your sim card
- perform a reset of your network settings
- try your sim card into another compatible device see if calling works
08-06-2022 03:28 PM
Try restarting your device.
If you think it's a problem with Public Mobile, you can contact
https://publicmobile.ca/en/on/get-help/articles/contact-an-agent
