03-20-2025 09:13 PM
New to PM,
Samsung S21 RCS stops working after I join. Any ideas for fixing? Not supported?
03-20-2025 10:52 PM
hi @JDdoublesix
you just need to go to Google Message, Message Settings, RCS Chats and disable "Turn on RCS chats"
reboot the phone, wait 5 mins and go back to enable "Turn on RCS Chats" back and it will work
03-20-2025 10:45 PM
Does calling and data working?
Resetting the Network setting and that didn’t work.
Contact a CS_Agent to investigate the issue. Their hours are 9:00am to 10:00pm EST so keep your eyes on your Messages in the morning.
03-20-2025 10:15 PM
@JDdoublesix wrote:New to PM,
Hello @JDdoublesix
I'm an iPhone guy but a simple Google search found this.
https://www.youtube.com/watch?v=C1kFq1tCFdA&ab_channel=AlohaAndroid
Can't hurt to try.
