07-29-2023 02:56 PM
I’m not able to log into my original account because the number is completely different, so how am I suppose to pay for my service or check my usage
07-29-2023 03:01 PM
Yea! It worked! Thank you so much 🙂
07-29-2023 03:00 PM
you can change the phone number back to the correct one after you logim to My Account, so, let's help you to login first
Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
07-29-2023 02:58 PM - edited 07-29-2023 02:58 PM
@HillR Try tapping resend code a few times . You should get option to send code to email instead . If still no luck . Please submit ticket with support to help you re gain access to it
privrate message To CS_Agents click
VVVVV Link below VVVVV
