2 weeks ago - last edited a week ago by computergeek541
Is it just me or do you all have an issue sending text messages. I’ve been with PM two days now and all my text go unsent. What should I do
a week ago
self solution removed
a week ago
HAHA yep same here. it's been 5 days so far and all i hear is birds chirping...
a week ago
If they ever reply to my messages I would probably have a heart attack from
the excitement of getting a feedback
2 weeks ago
HI @Cregdt
if Chatbot ticket does not work, then just use the easier way to submit ticket, just message CS_Agent directly here:
2 weeks ago
Thanks ticket doesn’t work but I will keep trying
2 weeks ago
My voice mail works as expected. Check if you phone calls correct number when pressing '1'. Try calling access number directly to confirm if it is your phone or vmail in general issue.
Texting does not work for new customers. They have to open a ticket so agent can do something on PM side in order for SMS to start working.
2 weeks ago
HI @Cregdt
with Voicemail, are you using iPhone? if you are , you might want to disable iPhone's feature Live voicemail
and the iMessage and sms problem, if only SMS an issue, it is a PM system problem with new activation. Voice, data both work but just SMS is the problem. And with the SMS problem, it will affect account verification. PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 weeks ago
The voice mail feature doesn’t work I have messages but can’t get them
the iMessage or text feature doesn’t work I can’t send and receive messages.
the reception to get calls in my home in Quebec is spotty
anyone know how long we will need to suffer before we get decent service
2 weeks ago
@Cregdt You can get the SMS problem fixed by customer service, if the chatbot (icon bottom right) doesn't work for you then send agents a private message using this link
An agent will reply at the envelope icon top right or tap your avatar for Messages if there's no icon. Their hours are 9 a.m. to 10 p.m. ET so you may not get a response this evening.
2 weeks ago
Hello @Cregdt
Public Mobile is dealing with issues when it comes to SMS on Android and iMessages and FaceTime and such. There is no ETA of when it will be resolved. Here is their announcement.
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features, and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
Keep an eye on this thread as they SHOULD update it when things are fixed.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
2 weeks ago
Check your messages here. It doesn't always show until you actually click the picture. ( mine doesn't)
2 weeks ago
watch the little envelop icon on top right side of page will be highlighted when they respond to you.
Whats the nature of your questions...maybe we can help faster than they can.
2 weeks ago
I’ve been with PM for six days now and despite several private messages to CS_Agent be never heard back from them.
do they exist?
2 weeks ago
@Cregdt Sorry, this is an issue for most new members. It's been happening for about 2 weeks now. Message cs agents separately for them to re provision your account.
