Monthly Plan renewal issues
Siva7975
Im getting message to renew my plan but when I tried to login, its not allowing me to login via mobile number and email id as well. How to renew my existing plan for the mobile numer?
Siva7975
Ok, I will reach the PM support again. Thanks for the prompt response. appreciated.
hi @Siva7975
you don't want to select new plan or so.  you still need to ask PM agent to help.  Please use the link above to message PM agent
Siva7975
Hi @hTideGnow
Thanks for the quick reply. I have registered again with the same mail id and now its asking to select a new plan and proceed with purchase of a sim card. Not sure how to reactivate my old/existing number now due to this.
hi @Siva7975
you will need to clear up the login issue with PM support agent.  You can submit  ticket by direct message:
 And if you want to renew the plan first, you can buy a voucher from Shoppers Drug Mart or Loblaw's and then load the voucher using *611
