Dbl acct
SandraCl26
When I renewed my husbands phone I somehow ended up with 2 accts. I’d like to cancel one of them so I’m not paying dbl. his number is 250-xxx-xxxx
Edit by Dunkman: removed personal information
2 REPLIES 2
Dunkman
@SandraCl26
By simpling renewing your plan, you should not have created a second account.  What exactly happened? Were you double billed?
Maybe you added extra funds into one account.  You would have needed to activate a second account with a different SIM card and usually a different email address.
P.S. I removed your phone number from this public forum
hi @
this is just a community and we are customers like you . Remove your phone number
For PM account, one email for only one phone number.  You must have another login for your other account.  if you are unsure which login for which account, ask PM agent to help
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
