05-14-2026 11:56 AM
Hi,
I have a 4G device and I got a message from Public mobile as:
Public Mobile update: Your device uses our 3G network. Starting June 15, 2026, you will see a $5/mo 3G usage price increase on your bills if you continue using this device. Your monthly price will change from $29 to $34.
Switch to a 4G LTE/5G device to avoid this amount on your bill starting on your following renewal. You can cancel your subscription without penalty until 30 days after the effective date of this change.
For more information: publicmobile.ca/sl/pQmBlGKnxI
Can someone help please, I have 4G.
Regards,
Sharmin
05-25-2026 04:41 PM
Thanks that worked.
05-25-2026 04:30 PM
HI @Sharmin
use this link
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/401296/tab/all
then click X on the top right of the pic
05-25-2026 04:26 PM
Hi,
That didn't work somehow, I didn't get a X on the top right.
Regards,
Porus
05-18-2026 04:41 PM
To delete the photo, click on your avatar picture and click on My Profile. Scroll to the pic and click the x in the tp right.
05-14-2026 01:52 PM
Hi @Sansan,
If you are the mode and can delete my IMEI number which got posted by mistake I would appreciate it.
Regards,
Porus
05-14-2026 01:49 PM
Hi @Sansan
I checked the page and it put in my IMEI, seems my device is VOLTE compliant even by Public Mobile's own database:
So if that is the case, why did I get the message for the 3G charge?
Regards,
Porus
05-14-2026 12:21 PM - edited 05-14-2026 12:21 PM
@Sharmin what's the 4G phone do you have? Please note the 4G refers to accessing the internet and not for making a receiving phone calls.
Your phone could be using the 3G service for calls hense the reason for the message and your need to purchase a new phone soon to avoid loss of service.
You can check if your phone is compatible in the link below.
