05-25-2026 04:09 PM
For a month or so, I can't access my online banking accounts because I don't receive the Verification Codes they send me . I'm a senior and wonder if I deleted or changed message settings on my cell phone.
Can someone access my phone and check it out.
05-25-2026 04:34 PM
This will probably require a face to face help with a friend.
But you can try the following:
Ensure that they have your correct phone number.
Check your messaging app to make sure that none of those contacts are blocked or marked as spam.
Go to your apps, find the Message app. Go to storage, and clear cache.
Restart your phone and see if you get any.
Only as a last resort, would I recommend a network reset, but it could help.
05-25-2026 04:28 PM
so, it was working on this phone before?
can you receive inbound calls?
If you are using an Android, uninstall Google Message, reboot phone and reinstall (or ask someone to help with this)
if you need PM to refresh the account , please open ticket
you can submit ticket by direct message:
