05-25-2026
12:13 PM
05-25-2026
12:41 PM
NDesai
Hello,
I'm writing to report that a number of my text messages have suddenly disappeared from my phone. Specifically, all messages under the contacts "JulieAnt" and "Julie" (which are my own number, used to save personal notes and reminders) are gone, as well as years of messages between myself and my wife, Josee. I did not delete them and have no idea why they disappeared.
I need to know what happened, whether Public Mobile played any role in this, and whether these messages can be recovered. Please escalate this to the right department and respond in writing as soon as possible.
My phone number is 416-xxx-xxxx.
Thank you,
Orville Hasfal
416-xxx-xxxx
05-25-2026 03:34 PM
They were gone just 1 day ago. Thank you
05-25-2026 03:34 PM
Ok. Thank you
05-25-2026 02:22 PM
In the settings of your Samsung. In Settings-Apps-Messages-gear icon top right-More Settings-Is the Delete old messages button disable for message to be deleted after 1000 texts. If it is enabled then it will automatically delete older messages more than 1000 texts.
05-25-2026 01:31 PM
@antonhaz wrote:Wow!...I still have messages from other numbers but they may be not as many messages to those people. No, I do not have that auto delete. I wonder if there is a way to recover lost text? The police do that when they have reaasons to as far as I understand. Maybe there is a way.
Thank you
HI @antonhaz
Pretty much no way unless you get Police involved. Even with that, they won't be able to recover text from too long ago
05-25-2026 01:29 PM
Thank you
05-25-2026 01:16 PM
I have text messages in my phone for over 10 years. Only time they would be deleted is if you deleted them, your phone is automatically set to be deleted after certain time, you changed phones.
When I changed my phone, the old messages were stored on the old phone and the new messages started on my new one. Lucky I still have my old phone .
05-25-2026 12:58 PM
I have a Samsung Galaxy Amp Prime 3....I hope that helps
05-25-2026 12:54 PM
Thanks. I have no idea what happened, I checked the things you suggested but no help. The thing is, I had those text for long time, and included passwords etc. I wonder maybe too many text were saved, and the system might want to remove them for space...Anyway, I thank you for you reaching out. Appreciate you.
05-25-2026 12:45 PM
@antonhaz wrote:Thank you for that. I cannot for the life of me, figure out what happened to my texts...Very strange
What phone do you have? Are you still using the same texting app as before? What about other chats? Possible some of them were archived?
Public Mobile definitely has nothing to do with this. It must be something on your phone, settings or backup related?
05-25-2026 12:34 PM
05-25-2026 12:30 PM
Please note this is a public community so no personal informational should be provided here. If you want to reach a Public Mobile staff member, you must use the orange chatbot to create a ticket.
It is not possible for a service provider to access your messages and to delete them. Check your message app to see if you have messages set to auto delete after a certain time frame.
If you have a cloud base service, you can check to see if they might be stored there. If not, unfortunately they are permanently gone.
