Physical vs eSim
Woomera01
Happy with my service , BUT I'm in a bit of a deadspot @ home and signal is weak . No problem once I leave my house 🙂 Have new phone with eSim capability . Is switching to an eSim likely to do anything to improve my coverage ?  Thanks
Woomera01
Moto power 5G ....I do better than most visitor who beg for my wifi password as they have NO signal at all ...as I said , it's only at my house ....even on the street infront of my house I have better luck than in the house itself . Thought it might be worth a try  😞
hairbag1
@Woomera01
probly won't make much difference which sim to you. Try using 4g/LTE instead of 5G.
hi @Woomera01
no, eSIM and physical sim is the same in terms or network connectivity, it won't make any improvement
it is the phone itself.  What phone do you have?
