4 hours ago
Joined August 1. When joining, app said should have another phone number in case of problems so got number on public mobile. Transfered phone number from telus which is now on my phone/account. After logging out I can't log back in because verification code goes to public mobile number which is not on my phone/account. How to get 6-digit code to go to number on my phone/account ?
3 hours ago
I only have one account, and only one email. I have submitted a ticket. Thanks for replying and link
4 hours ago
hi @jpmo you got the code but not the correct number? So, you have multiple accounts. If that is the case the account that linked to the number you want was with a different email
you can use Forgot email link to try to see if it helps. if not, please submit a ticket using the link provided above
4 hours ago
I eventually get code through chatbot on email but that does not get the code to go to correct number
4 hours ago
hi @jpmo
check if you can get the code via email
click Didn't Receive code or Resend code and choose Send email, and try to get the code via email
if you cannot login still , ask PM to help. you can submit ticket by direct message:
