Bad internet connection
Art8
What's going on with the internet connection? Every day the Internet is working worse and worse, a very good signal and a 5G+ icon, but nothing is downloading or downloading very slowly. It doesn't suit me at all
8 REPLIES 8
Andre99
Not good not working well !!!!
Art8
It was close to Leduc
@Art8  Be sure to update your IOS to the latest 18.1
Art8
Yes, of course I tried to restart the connection, but it didn't help. IPhone 15 pro max, iOS 17.6.1
slusagm
did you try Reset All Network on the phone?  and is it on a specific location or everywhere?
and what kind of phone do you have?  iOS or Android?
Chalupa_Batman
@Art8 wrote:
What's going on with the internet connection? Every day he Internet is working worse and worse, a very good signal and a 5G+ icon, but nothing is downloading or downloading very slowly. It doesn't suit me at all
Hello @Art8
You can try to go into network settings and reset your networks and then reboot. Then use a speedtest app to see what speeds your getting.
Please note, Public Mobile does not offer 5G+ services. It may say 5G+ but it's not.
If you're still having speed issues, please create a ticket to a CS Agent can look into it for you.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
HI @Art8
what phone do you have?  did you also try 4G or LTE?  If you have a 5G plan, your speed on 4G or LTE would be as good as you are on the 5G network
@Art8  Might just be the area your in can check
Outage map in your area:
https://istheservicedowncanada.com/
also try phone set to 4G/LTE I didn’t think PM had 5G+ just regular 5G but test em all in different areas
