01-06-2023 06:23 PM
Hi there,
My dad still didn't get the text message for the Holiday Giveaway 2022. I created a post back then and someone told us to wait until Dec 15th. He still hasn't got the 'Holiday giveaway of 2gb data and 500min international call' text message.
He's quite upset as he's the only one who didn't get the message, but myself and the rest of the family all got this text message. How can I follow-up so that he get this holiday giveaway? Thanks!
01-06-2023 09:34 PM
Like this, @winciy0412
01-06-2023 09:32 PM
01-06-2023 09:21 PM - edited 01-06-2023 09:22 PM
Definitely @S2art - you have started something here, and for the better. Nice work!!!
@winciy0412 , if your notifications were disabled, tell the CSA you want the More the Merrier bonus data and international add-on manually applied.
It worked for @S2art - it'll work for you!!!
01-06-2023 06:50 PM
If notifications are deactivated on your account, and most likely that's the reason for not receiving the text.
This is why I did not receive a text.
01-06-2023 06:45 PM - edited 01-06-2023 06:47 PM
Per the original announcement, if you did not receive the text with the offered rewards, it was recommended to contact Public Mobile before the end of December.
Did you previously reach out to customer support staff to ask for the free rewards?
If you did not, it's likely you are out of luck. Sorry.
See details here:
01-06-2023 06:35 PM
Hi @winciy0412 ,
it could be a bit late. But try to open ticket with PM CS agent and hope they can still add it for you
at : https://publicmobile.ca/chatbot.
First type Contact,
01-06-2023 06:25 PM
@winciy0412 @You will need to contact support to see if they can make an exception in your case but the offer ended dec 31 /2022
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
