02-07-2022 05:53 PM
I am receiving voice messages from what I believe are blocked numbers. Why does this happen?
How can I turn off voice messages completely?
Service
02-07-2022 08:05 PM
Thank you
I will try these also.
02-07-2022 08:04 PM
Some only.
02-07-2022 08:00 PM
That's why I am wondering if you really want to turn off the option to leave a voicemail in case there are some important messages you don't want to miss like specialist doctor appointment times or family emergency messages etc....where as programming the different conditional and unconditional call forwarding can redirect blocked calls to one specific number ie. "This number is for outgoing calling only." where as others could go to a voip app with voicemail turned off etc... while any of your contacts could still just go to your pm voicemail.
02-07-2022 07:51 PM
OH, then it sounds like perhaps you have your device set to ring through only those within your Contact list.
Perhaps that is why those other 'non identified' or 'spam' callers went straight through to voicemail.
Just a hunch.
02-07-2022 07:48 PM
Not all callers. Some are reg folks with identified numbers unanswered by me. Normal.
02-07-2022 07:44 PM - edited 02-07-2022 07:44 PM
Glad you found a solution that worked - that's awesome!
Can you confirm, out of curiosity, were ALL CALLERS going to your voicemail, or just some callers?
Just wondering how (or if) that might have been happening to you... thanks.
02-07-2022 07:31 PM
There are other options that will help eventually lessen the amount of spam calls you get then instead of them still hearing a voicemail message indicating an active phone line they can by redirected to a variety of messages or a fast busy signal etc....or Lenny he's good for a laugh!
Thanks to our resident voicemail expert @Nezgar who has compiled many options to deal with unwanted spam calls.
Here are some of the phone numbers you can program your call forwarding to along with instructions in the original post of this thread and the Lenny thread.
02-07-2022 07:19 PM
Hi @sdthenc
i Search and i found this maybe is help you
How to Disable/Turn off Voicemail on iPhone
also you can try get in touch with Customer Support Agent (publicmobile.ca)
they can Disable Voicemail Feature from your plan,
02-07-2022 06:58 PM
@Meow wrote:
@Anonymous wrote:Get into voicemail
Is there anywhere complete guide to PM's voicemail?
I tried to set up silent greeting but I cannot delete what PM calls 'name' message. It looks like there are two type of recording: one is 'your name' (which me dumb started to record then stopped but cannot delete it) and then actual greeting message.
Bottom line is I want whoever reaches my vmail to hear silence...
HI @Meow do you want this? personalize greeting but with silence
If I understand correctly, you are trying to set a standard greeting message?
- From the handset, dial 1+ the 10-digit phone number + Send.
or - From a landline, dial the 10-digit phone number and press the star key to interrupt the system greeting
- Enter password when prompted
- Press 3 for Greetings options
- Press 1 for Personal Greetings options
- Press 6 to activate standard systems greeting
02-07-2022 06:55 PM
Thank you
02-07-2022 06:54 PM
02-07-2022 06:51 PM - edited 02-07-2022 06:52 PM
Are you receiving ANY calls that first ring through audibly before going to voicemail?
If not, check the following:
- Take off airplane mode
- take off do not disturb
- ensure the number calling you is not on blocked senders list
- disable any call-forwarding features
- turn off Bluetooth device if it's possible the 'ringing' is going through to it instead of device's speakers
- remove and reinsert your SIM card
- reset network connections
02-07-2022 06:51 PM
I will try now. Thank you
02-07-2022 06:47 PM
@LeePublic wrote:They might've been call spoofed numbers, keep blocking the numbers.
Blocking numbers is just waste of time.
Unless somebody is really harassing you from particular number, all those numbers you see are spoofed.
02-07-2022 06:47 PM - edited 02-07-2022 06:48 PM
@sdthenc : Get into voicemail
press 3
press 4
press 2 and record a greeting
Press 4 to turn on the greeting
Press 5 to turn off the ability to take messages
Exit out.
Edit: You would still get calls. They would still go to voicemail. They just wouldn't be able to leave messages. Or with the backdoor messaging, they wouldn't be able to leave a message.
02-07-2022 06:37 PM
SE
I would like to turn off voicemails?
Do not need.
I have listened to prompts but nothing leads to **bleep**ting off voicemail? Lol
02-07-2022 06:34 PM
what your device brand and model ?
and you want to turn off voicemail messages completely, no more voicemail from anyone ?
02-07-2022 06:14 PM - edited 02-07-2022 06:17 PM
@sdthenc : Extended Absence Greeting. So you record your greeting saying something like sorry I'm not taking messages here. Text me if you like. Click. You turn on the stop messages option and that's that.
pkaraa brought up the very valid other voice thingy which made me sit up and ask for your clarification. 🙂
Edit: There is an option in the general voicemail system to drop a voicemail on someone without actually calling them. You could test and verify if the extended absence blocks that. I should think it would.
02-07-2022 06:14 PM
@VIP_Tech wrote:Hi @sdthenc
when you blocked number is will be going direct to voicemail,,
but if your plan for $15 and listen to your voicemail
the Calls to voicemail will deduct from in-plan minutes.
so is not worth it you blocked number just ignore and delete.
HI @VIP_Tech I think you misunderstand what OP said
02-07-2022 06:13 PM
02-07-2022 06:12 PM
Hi @sdthenc
02-07-2022 06:09 PM
Voicemail via phone calls I think. The service that comes with my package?
02-07-2022 06:06 PM
They are no ring calls straight to my voicemail. That is why I assumed they are blocked. I don’t actually know.
02-07-2022 06:05 PM
@sdthenc : Are you talking about SMS/MMS with a voice recording? Or are you talking about a voicemail message via phone calls?
02-07-2022 06:04 PM
I will try this.
Thank you
02-07-2022 06:03 PM
HI @sdthenc What you mean t by "believe are blocked numbers." ? did you block the number?
or you just meant those are funny V number on the call display? If it is those V number on the call display, ignore the calls, just caller id spoofing. Very common but annoying way of scam calls
02-07-2022 06:01 PM
Thank you.
They are leaving msgs without it ringing?
How do I turn off voice msgs?
02-07-2022 05:58 PM
When you block a number and they call you then it might give them a busy tone or they go straight to voicemail without ringing. That way they can leave a voicemail for you.
Voicenotes in SMS/MMS is different. It will go in blocked area and you'll get notification.
I have several in my blocked area, once a month I clear everything off.
02-07-2022 05:56 PM
@sdthenc : There is an option in the voicemail system called Extended Absence Greeting. It then opens an option to not allow any messages to be recorded.
02-07-2022 05:55 PM
