MMS (Sending Pictures via Text) Stopped Working
Avatar
Hi Community,
I am on the $15 plan, and for some reason, I am no longer able to send nor receive pictures via text anymore. It used to work perfectly fine without issue. I am on iOS and have my cellular data on. Is there something going on here?
I also know someone else on the $15 plan that is having this issue. Is this only happening with the $15 plan or is it something else that's causing this to not work?
If someone who has the $15 plan try, that would be great. Also, if you have a different plan using 4G or 5G please give MMS a try and send a picture to someone and see if it works as well!
Much appreciate for the help in advance everyone!
9 REPLIES 9
CrackerJacc
I know on Android the APN name is case sensitive!  Make sure the APN name is all caps like below.
Avatar
Yes, thank you! This has to do with it. 🙂
I will just switch to a new model soon. I did not know that they had MMS changes in place.
Avatar
Regular SMS messages send and deliver properly, just not sending texts with pictures in it via MMS.
I don't even have iMessage toggled on at all. I don't use it these days.
Phil_Adelphus
@Avatar   Is it only MMS, or does SMS not work either?   Can you check Send and Receive in the iMessage settings and make sure your phone number is checked for both?
Avatar
Hi, thanks for responding! I'm not looking to use iMessage. Rather, I mean real text that attached a picture to be sent to a contact.
Much of the details were explained to another user above. Are you able to send pictures over to someone with actual text (green bubble)?
Thank you!
Avatar
Hi, thanks for responding! I'm not looking to use iMessage. Rather, I mean real text that attached a picture to be sent to a contact. I'd much rather use messaging services like iMessage and others, but these contacts of mine are not tech savvy and use these things. Which is why they choose to use MMS to send photos over.
Were you able to do this over actual text (green bubble)?
Dunkman
@Avatar
One of my $15 plan was able to send picture message right now.
Might want to update your IOS on your phone.  Do you still have data availalbe on the $15 plan.  iMessage requires either data or wifi connection.
HI @Avatar
you can send iMessage no problem?
check the iMessage Settings
From a Home screen, navigate: Settings , Messages
Tap from the following Messages settings to turn on Switch On or off Switch Off:
Tap the iMessages switch to turn on
Tap the Send as SMS switch to turn on
Tap the MMS Messaging switch to turn on
Tap the Group Messaging switch to turn on
