12-11-2024 02:43 PM - last edited on 12-11-2024 02:44 PM by computergeek541
Hey,
I have been with PM for three years, with the same SIM card and plan, and mostly things have been working for me. However, three months ago, when I crossed the border and came back to BC, my internet stopped working even though calls and texts still work. My plan shows that I have plenty of data (extra add-ons in addition to the monthly 3G). My internet only works with wifi right now, which is really frustrating when I am en route, and can't check bus times or directions.
I have a dual SIM phone, and I have shut the phone off and on again, switched the SIM cards, but no results. The Canadian SIM is selected as standard for calls, and "use of mobile data" is turned on.
One thing I just noticed now is that when I go to "sim cards and mobile networks" and then on "further settings," the section for "IP address" and "DNS server address" is greyed out and I cannot click on it.
Can anybody tell me what might be wrong? Why can't I use my mobile data?
Thanks, Sarah
12-11-2024 05:01 PM
@SarahKu happy to hear it's working. You mentioned in your first post that data issues began when you returned from the US, try to keep a screenshot of your working settings just in case any future trips cause the same problem, although they really shouldn't.
12-11-2024 04:45 PM
Hey eddieO,
after turning the phone off and on a few times, the data is now working. There was definitely a problem with the APN content, but whatever it exactly was in the end, who knows!
Thanks for your help!
12-11-2024 04:29 PM
Hey, I did restart my phone, but data still won't work.
I sent a ticket to IT and hope to hear back.
Thanks for your help so far!
12-11-2024 04:18 PM
try restarting the phone now that you have the settings added in.
If you are still stuck I would reach out to a support agent. You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
12-11-2024 04:16 PM
Actually, more categories popped up:
Name - APN - proxy - port - user name - password - server - MMSC - MMS proxy - mms port - mcc - mnc - type of authentification - APN type - APN protocoll - APN roaming protocoll - carrier - mvno type
I filled out the categories you sent me, but the data is still not working 😞
12-11-2024 04:07 PM
Hey eddieO,
none of the info of the APN was defined, so no wonder nothing works.
Thanks for sending the APN info. However, I do have a question since my phone is German and some of the names are not exactly the same. In order, these are the categories my phone is listing:
Name
APN
Proxy
Port
User Name
Password
Server
Basically, that means that I am not sure where to put in the http address (MMSC).
Thanks.
12-11-2024 04:03 PM
@SarahKu wrote:Hey will13am,
I reset the network, and the options for APNs are Koodo, PC Mobile and TELUS. Can I choose one of these, or do I need to add another APN? I remember now that this was the issue last time, but I don't remember the info I put in for proxy, port, password, server, etc.
Thanks.
The name of the APN is less important than the content. See the link below for APN settings. If none of the 3 APNs you noted have data that is identical to the link, then add your own APN.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
12-11-2024 03:50 PM
12-11-2024 03:46 PM
Hey will13am,
Thanks.
12-11-2024 03:35 PM
12-11-2024 03:32 PM
I am using Redmi 9 (Miui).
12-11-2024 02:57 PM
@SarahKu wrote:Hey,
Thanks, Sarah
@SarahKu , what phone are you using? Can you try a network reset.
12-11-2024 02:49 PM
@SarahKu, are you able to try your SIM in another phone to see if it works? If not, try hTideGnow's suggestion or reach out to a support agent. To reach an agent you will need to open a ticket through the Chatbot:
12-11-2024 02:49 PM
I did not use a travel sim in the US. I took my phone as it was and only used wifi at places that had it.
12-11-2024 02:45 PM
hi @SarahKu
when you were in US, did you use travel sim card there?
try Reset network settings and see if it helps
