12-12-2024
10:30 AM
12-12-2024
11:00 AM
computergeek541
iPhone 14. Data was working. Now stopped. Canadian in Nevada.new to public mobile.
12-12-2024 05:10 PM
Try disabling 5G in your network settings on your phone. Additionally, Nevada (and surrounding states) does have many areas that are dead spots regardless of carrrier
12-12-2024 12:59 PM
could be problem with the network. did you try manually connect to T-Mobile or AT&T or Verizon ?
12-12-2024 12:57 PM
I have can/us/Mexico talk 50 gig data. Used for driving directions 2.5 hrs. Checked emails weather. Used .81% of 50 gigs . Then stopped working. Can make phone calls .no data .
12-12-2024 12:47 PM
Phone worked well for 24 hours .have used 5% of data. Used data for google maps I driving directions for 2-3 hours . Then no data. Can make phone calls. .? Did not change any settings
12-12-2024 10:46 AM
Is your plan Can/USA/Mex?
Do you have USA add-on? Maybe you ran out of data or data expired.
12-12-2024 10:31 AM
hi @Bradkolpin
so, you have a roaming plan or roaming add-on? try to change the network mode to 4G or LTE and connect to AT&T or T-mobile or Verizon. Try all 3 networks
