Spam Callers
12-12-2024 02:17 PM
Can I select an option for callers to press a number prior to the call coming through to help avoid spam callers? I believe Koodo and/or Freedom have this feature.
Service
12-12-2024 05:23 PM
the recidivists aren't telemarketers and aren't affected by the do not call lists. They're what you call...free-lancers ! Just don't answer call call from any number that you don't recognize.
12-12-2024 05:08 PM
Register your number on the government's do not call list. That way you will get less telemarketing calls
https://lnnte-dncl.gc.ca/en
12-12-2024 04:30 PM
No such option at PM.
And do not try to block every spam call as numbers you are would be blocking are most likely spoofed or computer generated.
12-12-2024 02:55 PM
to minimize calls from spammers...get in the habit of not answering calls from numbers you don't recognize. If it's a legit call, they can leave you a message and you can call back if you wish. Using this method, calls to my number have diminished from a few calls daily to 2 or 3 in a month.
12-12-2024 02:34 PM - edited 12-12-2024 02:35 PM
@Bob80 Not much anyone can do about spam calls best to just ignore them , some will chage phone number but that’s dosent always work either just matter of time before that number starts getting the spam calls . Some will silence or block unknown callers too but then You need to update your contact list or avoid missing important calls from schools dr office etc . But best to just ignore it
