12-12-2024 04:56 PM - last edited on 12-12-2024 08:35 PM by computergeek541
My account shows payment, but my phone is saying no service. Went online to my bank and shows payment payed
12-12-2024 05:57 PM
try turning off your phone, wait 5 minutes and turn your phone back on. If still not service, then go into settings and see of you have the correct PM settings for your phone type.
12-12-2024 05:09 PM
@smartguy1998 check
Outage map in your area:
https://istheservicedowncanada.com/
if no outage and account is active and rebooting the phone or resetting network setting doesn’t help ask support to re fresh your account
12-12-2024 05:06 PM
Check your app or your account on the website to see if the payment did go through successfully. What phone are you using and are you a new or older customer.
Make sure you are in a location where there are Bell/Telus towers as well.
12-12-2024 05:06 PM
no service for 2 days, been with PM for aver 5 years. I have removed sim card a couple times already.
12-12-2024 05:01 PM
If your account says Active, you should have service.
If you have physical SIM, try to remove it and insert it again. Check your SIM in another pone (if possible).
How long you have been PM customer and since when you have this issue?
