Help
Mira5
How do I send a direct message as my plan has stopped working. I need to change my payment information
1 REPLY 1
NDesai
@Mira5 Are you not able to login to your account and update the payment information? You can also use the PM app to update information. If it asks you to send OTP to your number, select resend option and send the code to your email instead to login.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
