Lost Iphone
WalterG
I lost my I phone and have no access to the sim card. It has not been found.
I need help to get the sim card and phone number transferred to the new phone. Please help. I have no access to my email so I cannot provide those details and have not been able to retrieve it because I do not have my passwords. Please help.
Typhon
The first thing that I would do is lock the credit card associated with the lost phone's account.
@WalterG
Did you try login to your iCloud account and then on Find My?
Your only option is to private message a CS_Agent by clicking on the envelope icon on your computer if you have no access to your email or forget your password.
@WalterG  To log into your account try tapping resend code a few times . You should get option to send code to email instead . You will need to call around to local Telus Koodo stores for availability for PM SIM card . Or Oder one from Amazon . Once you have SIM card in hand . You log into your my account and SIM card swap the number like this or get support to do it for you
SIM  SWAPPING  profile tabs
Note only do this on lap top or computer/ not mobile device
or submit ticket with support . To help you regain access to your account and sim swap the SIM card for you
private message   To CS_Agents click
@WalterG
since you don't even have access to your email address you will have to open ticket with support for help with sim replacement and get the login back,  messaging them here directly:
