01-15-2022
05:10 PM
01-15-2022
07:06 PM
Dunkman
Will not verify my email says login failed
01-15-2022 05:17 PM - edited 01-15-2022 05:18 PM
Then you would need to private message CS Agent to ask for their assistance. Please include all your account info so they can authenticate your request.
01-15-2022 05:15 PM - edited 01-15-2022 05:16 PM
I assume that:
(1) You've tried the forgot password option,
(2) You have an active SIM with PM already, and
(3) Your question pertains to logging into selfserve.publicmobile.ca?
Please confirm.
01-15-2022 05:16 PM
Yes
01-15-2022 05:21 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
only them will reset for you,
Here’s How To Contact Customer Support Agent,
Good Luck.....
01-15-2022 05:30 PM
If you are trying the forgot the password and your email id is not recognized and if that is the only email you can think of then contact support agents by sending a direct msg to CS_Agent and they ll be able to help you after authorizing you in both the cases if you want to get your email changed on the account or the password to login.
01-15-2022 05:37 PM
@Bradley1 wrote:Will not verify my email says login failed
@Bradley1 - where are you trying to login?
In order to log in here: https://selfserve.publicmobile.ca/Overview/
You must be a current customer with an Activated SIM card.
If you used to be a current customer, but have been in suspended status for nonpay for over 90 days then you lose access to your Self Serve account, as well as lose your phone number and Public Mobile account.
If you are trying to log into the area to purchase SIM card or phones, than that is a totally different login area and system.
You really don't have to create a login at these locations (although, you can, it is just different than your Self Serve credentials); OR you can process to make purchases as A Guest as well.
01-15-2022 05:51 PM
I did in the self serve, like I normally do and done previous
01-15-2022 05:56 PM
01-15-2022 06:44 PM
Yes
