07-10-2019 09:29 AM - edited 01-05-2022 05:49 AM
Hi Community,
Thank you for the positive comments on the new phone compatibility checker. As you may know, we partnered with willmyphonework.net and utilize its extensive catalog of mobile devices. With that said, you’ve highlighted to us that there are devices that are not captured still, and we want to keep track of that here to provide feedback on a regular basis.
Please comment below your phone make and model that wasn’t found on our checker and we’ll be sharing on a monthly basis back to our partners.
Thanks,
Public Mobile Community Team
List of missing devices added (July 2019)
Click below to open the list of devices:
List of missing devices added (August 2019)
07-06-2020 08:02 AM - edited 07-07-2020 12:10 AM
@Naepalm wrote:
@Naepalm Whichever website that screenshot came from, I highly suggest not using it. It will only confuse people. The information provided is incorrect. Public Mobile does not have any 2g-type network. This could potentially cause people to think that a phone is compatible when it isn't.
07-06-2020 07:47 AM - edited 07-07-2020 12:08 AM
You can check this Telus IME# Check and it will tell you if it works on the network.
http://mobility.telus.com/devicecompatibilitycheck/?locale=en
Shows that it is compatible although it does not have use of all bandwidths.
( edit: picture removed) @computergeek541
Have a great day!
07-06-2020 07:40 AM
Xiaomi Redmi Note 9s
Looking at getting this phone but it's not on the compatibility list. Please respond if you use one on this network
06-29-2020 11:28 AM
It is compatible with PM.
06-29-2020 11:15 AM
Hey I'm curious about the packard bell A5000
GSM/GPRS/EDGE 850, 900, 1800, 1900 MHz; 4G HSPA+ 850, 1700/AWS, 1900, 2100 MHz; 4G LTE 2, 4, 5, 7, 17
thanks for your time!
06-17-2020 08:59 PM
@JJordens17 according to this site its 100% compatible has both the required 3g and 4g LTE bands. Stay safe. https://www.phonegg.com/phone/13036-Samsung-Galaxy-A51
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
06-17-2020 08:31 PM
I just received a Samsung Galaxy A51 (model SM-A515W) as a gift and it does not appear on the compatibility list. Thanks
06-12-2020 02:53 PM - edited 06-12-2020 02:54 PM
@Lise01 wrote:Hi. Is the Samsung a51 compatible? Thanks!
@Lise01 generally yes. There are a few variants of the A51 sold in other parts of the world, but if you acquired it in North America it is definitely compatible.
EDIT: there are Russian and Autralian variants that I'm less sure about, but the Global versoin SM-A515F/DSN (Global) and Latin American SM-A515F/DS (LATAM) will certainly work. I'm not sure about the Brazilian variant either actually.
06-12-2020 01:47 PM
05-21-2020 05:09 PM
@pazmariano Set your phone to 3G and try connecting. I'm assuming you already have activated your card?
05-21-2020 05:08 PM
@pazmariano restart your phone, enavle data and try to send an mms text message. If that works, your APN settings are correct. Log into your self service account and see if you have data available it should look like xxx/ 250mb at 3g speed. See below.
05-21-2020 04:52 PM
Hi @gblackma,
Thanks for your suggestion. Tried the steps but still failed to connect using mobile data.
05-21-2020 04:46 PM - edited 05-21-2020 05:03 PM
@pazmariano reset your network settings and restart the phone. Samsung's will usually propagate the correct APN settings for the phone.
Enable data, Restart your phone, reenter your wifi if applicable. Try sending an mms text message and to surf the net. Stay safe. Welcome to PM.
05-21-2020 04:43 PM
Hi,
It's Model no is: SM-J730G
Thanks.
05-21-2020 04:42 PM
05-21-2020 04:40 PM
Hi,
Thanks for your reply. But I cannot enter APN details because it prompted settings are not available for the user. Hope anyone can help with this.
Thank you.
05-21-2020 04:39 PM - edited 05-21-2020 04:41 PM
It's 100% compatible has both the required 3g and 4g bands @pazmariano . Stay safe. The PM SIM is a tri punch one fits all 3 of the sizes.
Note- your old providers account must be active to port.
05-21-2020 04:38 PM
Does it have this somewhere in the about section
850MHz, 1900MHz
Band5-850MHz, Band7-2600MHz
Band17-700MHz, Band5-850MHz, Band4-AWS, Band2-1900MHz, Band7-2600MHz
Because if it does then it is supported by Public mobile
05-21-2020 04:36 PM - edited 05-21-2020 04:37 PM
@pazmariano wrote:Hi,
It's Samsung Galaxy J7 Pro. Is it compatible with the Sim?
Thanks.
@pazmariano Yes, that phone supports all the necessary bands and will work without any issues. PM sim card are tripunch so no issues there either.
05-21-2020 04:32 PM
Hi,
Thanks.
05-21-2020 04:31 PM
Please include Samsung Galaxy J& Pro in the list so I can use my mobile data soonest because I needed it at work.
Thank you.
Maria Paz Mariano
@pazmariano If the J3 Pro is the North or South American model it will work without any issues.
05-21-2020 04:25 PM
Hi,
Thank you.
Maria Paz Mariano
05-20-2020 02:15 PM
Looking to see if there is compatibility to the Samsung A6?
05-06-2020 03:49 PM
@pr4mr wrote:Wasted time and money on sim card and plan, and my phone says invalid sim card!
phone is LG L44VL
Sorry, but a phone with only CDMA and LTE won't be any good here. While LTE might work (depending on frequencies supported) for data an text messaging, you won't be able to make or receive any phone calls with this device. That device isn't really any good for any carrier here, so I highly suggest purchasing a different phone.
05-06-2020 11:28 AM
phone is LG L44VL
04-01-2020 03:44 PM
LG Q6, model number LG-M703
03-03-2020 09:17 AM
@NicoleStates wrote:It's also missing Samsung Galaxy Alpha ( SM-G850W) . Does anyone know if this is compatible?
Yes, it is. This is a Canadian-specific variant.
03-03-2020 09:17 AM
Yes it will work.
03-03-2020 09:12 AM
02-29-2020 02:51 PM
Please add Samsung Galaxy A50 to your list of compatible phones.
