Oneplus 8T and Volte Compatibility
T250cc1
Hi, use Public Mobile IMEI compatability checker. It shows my Oneplus 8T is compatible and will work with the Volte network, Telus compatibility checker says my Oneplus 8T is not compatible and will not work on the Volte network. What gives, I though Public Mobile is Telus.
@T250cc1 wrote:
No Volte button in settings. Even my latest phone Samsung S25 Ultra does not have Volte setting. Making phone calls does not show LTE/4G icon and the call display does not show HD or HD+ icon to identify what type of phone call is being used. By the way, do you need to enable data in order to show the network icon? I know when I'm making phone calls on my Samsung with data enable, the 5G icon stays on when I'm making phone calls. If I make phone calls without data enabled, no icon is shown.
HD voice is not the same thing as VoLTE.  Please ignore all of the details revealed through internet searches that show websites that claim that HD voice is required for VoLTE.  That information is completely wrong.  HD voice uses a group of CODECs and gives no indication that an LTE network is being used.  While there are some HD codecs that does require certain network types to be used, that isn't the case for all of them.  Public Mobile has had HD voice available for several years on the 3G network.
As for no signal type indicator in the notification area, this is usual behavior for most modern smartphones when there is no data connection (or data has been turned off).
T250cc1
hairbag1
@T250cc1
the "new" volte checker could have a few bugs to work out. Is there a VoLTE enable button or slide in Settings ?
Try this...turn OFF wifi and make a local call. Does the call stay on LTE/4G or does it drop to 3G. If it drops to 3G...you don't have a VoLTE enabled cellphone.
added...here's the latest list of VoLTE phones on the PM network..
https://www.publicmobile.ca/en/get-help/articles/volte
