SIM BLOCKED
rowlly
I was try to lock my SIM and into issue. It got blocked. How do I obtain a PUK from my carrier to unlock it?
1 REPLY 1
@rowlly
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket:  https://urlshortner.tiia.ai/Oyn1L6
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
