08-26-2020 08:58 PM - edited 01-05-2022 12:56 PM
The phone is locked to PM. I need PM's SIM network unlock pin. Is it 1234 or something else? Can the moderator provide the PUK code as well in case I need it while at the Shaw store?
08-26-2020 11:17 PM
08-26-2020 11:15 PM - edited 08-26-2020 11:16 PM
@lcouling wrote:The phone is locked to PM. I need PM's SIM network unlock pin. Is it 1234 or something else? Can the moderator provide the PUK code as well in case I need it while at the Shaw store?
A SIM Network Unlock PIN will never be 1234 or any other number that you can guess. It also actually has nothing to do wtih your SIM card or Public Mobile account, nor is it the same as a PUK code.
08-26-2020 09:11 PM - edited 08-26-2020 11:46 PM
@lcouling hi if it's a pm phone just call Telus to get it unlocked
* @computergeek541 I misread their post. I thought they were at the Shaw store and they were in a rush. 😉
08-26-2020 09:08 PM
Public mobile has not sold phones for a while. Are you sure that the phone is locked to Public mobile? The original carrier can unlock the phone for free.
If it is indeed locked to PM, you will need to contact moderator as described above.
08-26-2020 09:03 PM
@lcouling Contact the moderators and ask them to unlock it for you. It's probably locked to either Koodo or Telus. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-26-2020 09:01 PM
What kind of phone is it? Was it purchased through Public Mobile? The original selling carrier is the only option to have it unlocked. The cost to unlock a phone that was purchased in Canada is $00.00.
