Just signed up and no service…
FloraMargot
I’ve just signed up for the 90 day Subscription.  E-sim activated, no porting of a phone number, phone I’ve had for a couple of years and is not black listed, and I’m still getting the “SOS”.
I have done all the trouble shooting steps, including resetting the network settings. Still no luck.
On the coverage map I’m supposed to get 5G service. Hoping someone can help…
Really dissatisfied with Public so far.
10 REPLIES 10
@FloraMargot
Yes, 7 days/week
9:00am to 10:00pm EST.
FloraMargot
Still no luck. What I’m realizing is how flawed the PM app is.
We are stuck because it wants to send me a code to the number I can’t access in order to get into it, to change my Sim ID…
Is this a typical PM experience?
@FloraMargot yup, they do. Open ticket now. They usually reply with 2 hours or so, usually sooner
FloraMargot
Thanks! Do they work weekends?
@FloraMargot
have you open ticket with support yet?
would be a quick fix for them, open one:
FloraMargot
Tried this.. no luck 😞
@FloraMargot
It could be a provisional/backend issue on PM side…it happens.
Just contact a CS_Agent by private messaging on the envelope icon on your computer so they can investigate the issue.
@FloraMargot
You have already installed the eSIM profile and tried Reset All networks?
Just one more check,  if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim.  Then click Reset All Networks on your phone once moreand it will work.
if you don't have another active sim, then please open ticket with PM support
Yosemite_Sam
Is your phone carrier unlocked?
