HI @Jhh1 , usually it cannot be done.
However, since you are with PM , it is possible they can help you to port without the SIM. Just open a ticket with PM CS Agent and explain,, they can probably able to manually port for you:
https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
