05-20-2022 01:29 PM
I just received an e-mail this morning from Public Mobile regarding a new $25 Refer-a-friend bonus. However, I helped out a friend with my referral code just last night, before I received the e-mail this morning. Would my friend and I still be eligible to receive the bonus?
05-20-2022 01:32 PM
Well, you could ask agent to have a good will and apply new sign up bonus since you signed a day before they introduced this offer.
If ticketing does not work very first time, send then personal mail.
To contact CSA-agent, there are 2 methods:
Good LUCK!
05-20-2022 01:32 PM
Good LUCK!
05-20-2022 01:55 PM
Wouldn't hurt to try, no guarantees since it is starting today, but since it was so close they may make an exception
05-20-2022 04:17 PM - edited 05-21-2022 08:49 PM
Check the eligibility dates of the bonus referral credit. If you are not within the eligibility dates it's unlikely that customer support would give you the extra credit as they are pretty strict about this kind of thing. What time did you refer your friend last night? You may have qualified if you are in BC and referred them after 9pm pacific (for example).
Can you post a screenshot of your email? Remove any personal info first such as your name, email (it may appear in the small print at the bottom as well) and referral code as you don't want that info on a public forum nor is it allowed. Thx!
I was wondering if pm was going to have a response to Lucky's bonus referral credit offer?!!
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
