09-08-2024
04:10 PM
09-08-2024
04:23 PM
computergeek541
I am experiencing slower mobile data speed since I changed to 5G. This is weird is there a reason for that?
09-08-2024 04:26 PM
hi @KoMu what phone do you have? you don't need a 5G phone to enjoy the super speed. A 4G phone using 4G network can get speed close to 250Mbps
Try Reset all networks and try your PM sim card on another phone. Download speed test app and confirm the speed you are getting
09-08-2024 04:17 PM - edited 09-08-2024 04:18 PM
Hey @KoMu
To confirm, you have a 5G capable phone? Also, you should reboot your phone after changing and you may wish to reset your network settings. If it's still slow, you may wish to put in a ticket.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
