3 hours ago
Hey I have the Canada/us data and phone plan. So when I get to the states I won’t get charged with any extra roaming charges?
2 hours ago
Nope your won’t be charged. It is all included in the plan. Just remember to enable Roaming and also enable VoLTE.
If you are issues, you will need to manually connect to the AT&T or T-Mobile network.
