Voicemail
09-08-2024
01:49 PM
09-09-2024
10:15 AM
Dunkman
- Is there a way to deactivate or do away with VM on my Android since there's no 'calling' PM support?
Or is the only solution to keep my VM full?
Service
09-08-2024 04:01 PM
you cannot remove it but you can turn on extended absence.
- Call voicemail and log in with your PIN.
- press 3 (manage greetings),
- then 4 (manage extended absence greeting),
- then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
- Then press 4 to enable extended absence
- Last, , press 5 to dissallow anyone to leave you a message.
09-08-2024 03:19 PM
Thanks but the general idea is to have chronic voicemail leavers think that I don't have voicemail on my phone . I try letting my VM get full but then if I see them in person they tell me 'you need to delete messages, your VM is full."
Just can't win lol. But thanks anyway.
09-08-2024 01:54 PM - edited 09-08-2024 01:55 PM
Voicemail cannot be deactivated, @Ramshackle10
If you don't wish to use it, just ignore it.
You can go into the voicemail system, and while listening to the message, tap 7 to delete individual messages.
