09-07-2024
07:33 PM
09-08-2024
11:36 AM
Dunkman
09-08-2024 04:27 PM
thanks @computergeek541 , typo and corrected
09-08-2024 03:41 PM - edited 09-08-2024 03:42 PM
@hTideGnow wrote:hi @AndreaCoutu yes, only iPhone 2 and above has 5G. But with a 5G plan you have, you cam still get close to PM 5G top speed of 250Mbps even when you are using 4G network
The 2nd iphone as iPhone 3G? I'm assuming that was a typo and that was meant to say iPhone 12?
09-08-2024 02:31 PM
The plans are based on speed rather than how your phone connects. Ie any of the plans will allow you to connect with 4G or 5G if your phone is capable of doing so but the speed you connect with is limited based on the plan you have. My son has an iPhone SE so his phone connection is limited to 4G but he does have a 5G plan so he can get up to 250MBps rather than being limited to 100MBps if it is available.
09-08-2024 11:43 AM - edited 09-08-2024 04:27 PM
hi @AndreaCoutu yes, only iPhone 12 and above has 5G. But with a 5G plan you have, you cam still get close to PM 5G top speed of 250Mbps even when you are using 4G network
09-08-2024 11:18 AM
So it turns out that since I have an iPhone 11, it is not compatible with 5G. But I did Reset Network Settings and now the internet is faster. But it is just 4G
09-08-2024 11:09 AM
@AndreaCoutu It is 5G but slow 5G up to 250mbs unlike Telus 5G+ that’s up to 2GBps huge difference in speed . I have a old 4G plan that uncapped and it’s faster then the regular 5G then public mobiles 5G
09-07-2024 07:53 PM
It's 5G
Keep in mind, the 5G can be 'finicky' in that some have reported in certain locations that 4G LTE gives better consistency.
But when you get good 5G, it's just fine.
