3 hours ago
My current plans states the following:
50GB Data within Canada and the US at 5G Speed
5G Speed up to 250mbps
Unlimited Canada-US wide minutes and messaging plus unlimited international text and picture messaging
Calling Features: Call Display, Voicemail, Call Waiting, Call Forwarding, and Conference Calling
I will be able to use my phone without any addons in USA, and the data would also work, am I correct?
43m ago
@DannJK wrote:Just to follow up on this topic. I have the same plan, I'm new as of yesterday...I can call USA from Canada, call Canada from USA, call USA to USA? This seems like a really good deal. Three days of roaming fees equals all you can use Canada/USA?
Please seee the answer as previously provided. Yes, service is provided in both Canada and the US.
an hour ago
3 hours ago
Thank you so much for clarifying.
3 hours ago
He\y @Sura
Yes. 100%. You will not need to purchase any addons as everything is included. When you go to the US though, you MAY need to go into network settings and turn off automatic and then choose either AT&T or T-Mobile and then restart the phone. You should have no issues.
3 hours ago
That is correct. You will not need to purchase any add on while traveling in the USA with this plan
