12-08-2025 08:18 PM
I could not activate my cellular data after travelling, and my phone is iphone 16 pro max
12-08-2025 08:20 PM
make sure you remove your travel sim card, or delete the Travel eSIM
also, delete the VPN profiles, might have installed with your eSIM app
Then Reset network settings
