2 hours ago
I understand that only specific countries are allowed to call with special rates. Yet, my question: can I call other countries which is not part of such special rates knowing that the rate could be higher?
54m ago
@flah10 You could look at downloading a voip app like Fongo that has cheaper rates for international calls, you'd have to take a different phone number with that though and keep your current PM one just for use in Canada..
an hour ago
You cannot call any other country which is NOT part of long distance add-on.
2 hours ago
HI @flah10
sorry, no. If the country is not on any of the Long distance addon, then you cannot call at all. You will need to use the old style calling card to make the LD calls
