01-07-2023 01:52 PM - last edited on 01-08-2023 10:53 AM by Dunkman
Going to UK , middle east and France. Will need calling and data. Will people calling from Canada be charged for calling us.
10-01-2023 02:12 AM
Hey everyone! I've been researching the best SIM cards for international calling in the Middle East, and I stumbled upon publicmobile.ca. They seem to have some promising options, but I wanted to get some insights from the community here.
Has anyone tried using publicmobile.ca SIM cards for international calls in the Middle East? How was your experience in terms of call quality and rates?
Are there any specific plans or packages from publicmobile.ca that you would recommend for frequent travelers to the Middle East?
I've also heard about other SIM card providers for international travelers in the Middle East. Has anyone used any of these and can share their experiences or provide links to these alternatives?
What are the data speeds like with publicmobile.ca in the Middle East? Is it suitable for browsing and using apps while abroad?
Are there any hidden fees or unexpected charges when using publicmobile.ca SIM cards for international calls in the Middle East?
For instance, you can check out this link for more options: Best Dubai SIM Cards for Tourists and this link also have good information.
https://www.phonetravelwiz.com/category/local-sim-card-guides/airport-sim-cards/
Please feel free to share your thoughts and recommendations, and don't forget to mention any other SIM card providers that you think are worth considering for international calls in the Middle East. Your input will be greatly appreciated!
01-08-2023 04:28 AM - edited 01-08-2023 04:33 AM
Public Mobile has no roaming outside of the US. Depending on how important is is for you to still receive your pm services you can either suspend your services for up to 89/90 days or continue your services by scheduling a change plan on next renewal to the $15 plan and call forwarding your pm phone number to a voip provider (canadian) phone number before you leave Canada. You can also forward your texts with an app like Mighty Text but your Sim card must remain in Canada in a working phone left powered on and preferably connected to a charger/outlet.
Then with the use of a local or global sim card and/or wifi you will recieve your incoming pm calls and/or texts on their associated apps. The UK has many cheap prepaid Sim cards/plans with @Luddite 's option of giffgaff being one of them. Just check their terms as most but not all still include free roaming in the Eurozone countries that would cover France as well. This Middle East would require a separate Sim card (or e-sim). The UAE among others offer a free tourist Sim card available at the airport to cover your first 24 to 72 hours in the country (validity time varies) giving you enough time to seek out a local Sim card. Without knowing where in the Middle East you are traveling to limits any further advice I can give you.
Info on global sim cards...
https://toomanyadapters.com/international-sim-card-comparison/
Info on Middle East sim cards....
https://www.phonetravelwiz.com/buying-a-sim-card-in-the-middle-east-guide/
Free UAE tourist Sim card info...
https://www.visitdubai.com/en/articles/sim-card-for-tourists
Here are the options for your pm service when traveling (All rewards references are $$ rewards and do not apply to points rewards)....
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. If you are traveling for a longer period of time then suspend your service via lost/stolen again and repeat. Happy travels!
01-07-2023 05:02 PM
01-07-2023 02:21 PM - edited 01-07-2023 02:22 PM
No, @Pamag , not on your Public Mobile service as it's not usable outside Canada & USA.
Whether or not they'll be charged to reach you will depend on what service you may decide to acquire on your travels otherwise. (i.e. a local pre-paid SIM or VoIP service)
01-07-2023 02:20 PM
Nobody will be able to reach you as PM does not offer service outside of this continent.
You could try viop app as TextNow
01-07-2023 02:11 PM
You are not able to use your PM phone and service.
If you are not staying long at each country, you may consider using one of FIDO or Koodo's easy roam options for $15 per day (you could get a very good deal from them and cancel the service later). You would be able to use your minutes and data while visiting - calls made to and from Canada will be free.
01-07-2023 01:57 PM - edited 02-17-2023 08:33 AM
hi @Pamag your PM sim won't work there
For data access, use local prepaid data
Also, download VoIP app like TwxtNow so people can call you and you can call using the app for free
01-07-2023 01:55 PM - edited 01-07-2023 01:56 PM
There is no Public Mobile services available in Middle East and France, Edit and UK, so you will not be able to use your public mobile number there.
Best to use a wifi app or local SIMs when you travel there @Pamag
01-07-2023 01:55 PM
@Pamag @Your best to get local sim in the destination your going for the duration pm won’t work outside Canada and USA (with addons )
01-07-2023 01:54 PM
